Home › Forums › Viper Parts and Accessories › Underground Racing Twin Turbo 522" drivetrain and accessories
This is for a nearly complete drivetrain for your 2003-2006 Dodge Viper SRT 10. This engine was built by one of the best engine builders in the country, Underground Racing. The build sheet for this motor totals up to about 100k worth of parts and labor. I had it in my VOI9 Viper that I unfortunately totaled. The drivetrain has since been pulled out of the car and put on a shelf in my warehouse. This ad includes all of the following:
Engine, Transmission, Engine, Fuel System, Turbo’s, AEM Computer, Fuel lines, and much, much more. I will consider selling some of these parts separate, just ask.
DIRECT FROM UNDERGROUND RACING INVOICE:
Stage 3 Turbo System with Highly Modified Engine
1100 WHP on pump gas (93 octane)
1500 WHP on race fuel (VP-C16 117 octane)
Gen 2, 3 & 4 Viper models starting at $95,000 installedTwin Turbo Dodge Viper SRT
Underground Racing Custom Twin Turbo System
Custom twin 78mm turbochargers
2 Tial billet wastegates
2 Tial billet blow off valves
All exhaust fabrication to be stainless steel, mandrel bent, high flow and high temp heat coated
All air intake fabrication to be stainless steel, mandrel bent, high flow and show polished
High pressure t-bolt clamps for intake pressure tubes and v-band clamps for exhaust tubes
Electronic Boost Controller
Custom heat shielding
Underground Racing Custom 522 Stroker
Full blue print and balanced race short bock
Offset custom ground crankshaft
Custom billet rods
Underground Racing custom turbo camshaft
Custom reverse dish forged race pistons
Spiral locks
Clevite coated race main bearings
Clevite SBC coated race rod bearings
Total seal TNT file fit rings
Program billet main caps
ARP head studs
Striker cylinder heads
Upgraded valve springs
Titanium retainers
Pressure tested and etc.
Fuel System Upgrades
1500 rwhp Intank fuel system with quiet option
Billet fuel pump hanger for three High Flow fuel pumps
All Aeroquip stainless steel line and aluminum fittings
Custom show polished fuel rails
Aeromotive adjustable fuel pressure regulator
Custom 75lb injectors
Tuning Upgrades
AEM EMS standalone computer
Custom wiring harness to make Gen 2 AEM compatible with Gen 3 Viper
* Note: The AEM EMS is not ODB2 compatible.
Dyno and street ability tuning.This is a recipe to go Fast, Fast, Fast! This includes everything you will need turn key except for the intercooler and a couple of the intercooler pipes that were damaged in the accident. I WILL GUARANTEE THIS ENGINE TO BE AS PROMISED IF INSTALLED BY THE SHOP OF MY CHOICE. (see warranty paperwork) If you have any questions please feel free to call me anytime to discuss.
thank you,
Dustin
214-402-3044
