Home › Forums › Gen I / Gen II › Vacuum leak
Stupid question, but is your gas cap on tight? The most common cause of the 442 code is a loose or faulty gas cap allowing air into the Evap system.
did the gas cap already.. first thing I did.. next Dr Watson
need some help . now have code 442 small evap leak
I changed lifters to low bleed style on my crower cam. would low vacuum due to cam cause this. I clear the code drive for a day .. next start in the morning and POOF the code fairy visits
2001 gts
