When you replace your clutch and flywheel, always replace the pilot bearing, slave cylinder (with throwout bearing), flywheel bolts, driveshaft straps and bolts. Typical labor charge is about $400.
Dan Cragin said: When you replace your clutch and flywheel, always replace the pilot bearing, slave cylinder (with throwout bearing), flywheel bolts, driveshaft straps and bolts. Typical labor charge is about $400.
Good to know Dan, thanks. I’m sure they can still be added to the order.
I have done a few clutches in other vehicles, but just don’t have the time and would feel better about having someone that is familiar with Vipers doing the job right the first time. Has anybody had it done that might happen to remember a ballpark figure for the labor, I have purchased all the parts already.
