Home Forums Gen V Window adjustment
    • VENOM-TA
      Just installed new window regulators in both sides today and everything operates as expected except now there is a slight gap at the top back corner of each side. Window seals up and not really any wind noise when I drove it up and down the highway, just a noticeable gap where you can see under the window..
      are there any adjustments that can be made? It seems like it needs to go slightly back just a little..
      tried looking on the old forums but can’t find any details..
    • BSLSK
      Yes, you need to adjust the window bosses. Just loosen it and the window will have some slight adjustments you can make.
      • VENOM-TA
        Can you elaborate a little more, are you saying to loosen the bosses themselves as in where the bosses screw together with the window in between them or the bolts that screws the silver bracket to the bosses?
        • BSLSK
          Yes, that is exactly correct
Reply To: Window adjustment
Your information:
