Home Forums Gen III / Gen IV Window Indexing Problem
    • Joe Smallwood
      Does anyone know someone in Georgia (or the SE) who can do a software update for the BCM on my 2004 roadster to allow my driver’s window to index properly again?  I have already done the method in the Service Manual multiple times where you hold the window switch for 5 seconds in both up and down positions.  It will now index when the door is opened but does not index when the door is shut.  From what I have read, the next logical step would be to do a software update.  The Dodge dealerships I have asked all said they do not have what they need anymore.  Any suggestions would be appreciated.
    • Michael Kuchavik Jr
      Guest
      The window relearn procedure is quite simple. You put the window up and hold the switch for 3 seconds then press the window down and hold the button for 3 seconds. repeat this 3 times and that should do it.
      However when this begins to happen. its typically a failed window regulator. I attached a how to and where to send the regulator for a rebuild.
      https://www.havikperformance.com/resources/how-to-remove-a-gen-iii-v-door-panel-without-damaging-it
